charged for incoming calls originating in canada
  • Aug 28, 2023 3:50 AM UTC
  • 341 views
why on a $15 plan incoming calls are  counted in the 100minutes, the plan states incoming calls originating in Canada are free?
Best answer by Darius Koodo
Hello @str
I’ve looked into the plan specs for you and, the one offered on postpaid, states :
  • 100 outgoing nationwide minutes
  • Unlimited incoming nationwide minutes
Receiving calls from Canadian numbers within Canada, to Canada, will be unlimited. While checking the usage in the Self Serve account, you would be able to differentiate between outgoing and incoming.
  • Aug 28, 2023 3:54 AM UTC
That should be correct. However, they are likely referring to Canada-wide calls that are made from a Canadian number. Does the caller have a different area code from another country?
  • Aug 28, 2023 10:45 PM UTC
the callers all have Canadian numbers including my wife  that called me from our home line number
  • Aug 29, 2023 12:10 AM UTC
Is this a current or older 15 dollar plan?
  • Aug 29, 2023 1:53 AM UTC
I signed around May 20 ,2023, and at that time, the info I was given incoming calls were free
  • Aug 29, 2023 2:42 AM UTC
The terminology for both the prepaid and postpaid 15 dollar plans simply states unlimited incoming minutes and Unlimited incoming Canada-wide minutes with no fine print. Incoming calls while in Canada for your plan would be free. So I don't know why you're getting charged. I'll flag a rep to assist.
Darius Koodo
  • Aug 29, 2023 8:46 PM UTC
Hello @str
