cash advanced on my bill
  • Mar 31, 2021 5:09 PM UTC
  • 3 replies
  • 153 views
Joel's
Where can I see the balance on my account that I prepaid? I put $400 on my account so that each month they will just take my bill amount off this prepaid lump sum I put on my account and now I would like to view this amount, where can I do this?
Thank you
Best answer by Allan M
It should display on the home page of your self serve account. It looks like this on prepaid:
Allan M
  • Mar 31, 2021 7:16 PM UTC
  • Apr 1, 2021 6:30 AM UTC
Is this a postpaid account?
If you over paid your balance then you should be able to seethe credit when you login to self serve.
Joel's
  • Apr 2, 2021 1:39 PM UTC
Yes I found the balance now.
Thank you for your help!
