Can I bring my own device and use Koodo Prepaid?
  • Jun 29, 2021 2:57 PM UTC
  • 2 replies
  • 401 views
I'm looking into buying a phone outright from the manufacturer, and was wondering if Koodo prepaid is an option if I'm bringing my own device. I use almost no data so the prepaid with data boosters is the ideal plan for me, but I wanted to confirm before purchasing the phone that prepaid will be an option, since the Bring Your Own Phone plans are more expensive.
Any information would be greatly appreciated!
Best answer by MilkyWay
Yes, you can use your own phone on Koodo Prepaid. Make sure your phone is compatible with the Koodo network before purchasing it.
  • Jun 29, 2021 3:00 PM UTC
  • Jul 1, 2021 1:12 AM UTC
For compatibility, you can go at www.willmyphonework.net
