Hi there, I hope you’re doing well!
I’d really appreciate your support please. Two hours ago I purchased a yearlong plan to keep my phone number while studying abroad. However, after porting my number and paying for the plan, I discovered that I don’t have network access overseas. Since my phone isn’t working, I’m unable to schedule a callback, which makes resolving this tricky.
Could you please help me review my options?
Thank you in advance for your time and assistance!
A year long plan, as far as I know, only exists as a prepaid 360 day plan. This does not have roaming as an option at all. Can you double check if it is a prepaid or postpaid plan you got?
Hi Goran, thank you for your prompt response! I purchased the prepaid plan. I don’t need roaming as far as calls go, but was merely looking for a way to receive incoming MFA texts. Thank you
So that would be considered roaming.  Being able to connect to another country’s network (regardless of what features you are using).
Prepaid only roams in the US and no other country outside of Canada.  What country are you in while studying abroad?
Hi Dennis, thanks for your quick reply! Yup, you’re totally right! Lol I feel like an idiot. I’m in New Zealand. My goal would be to talk to a representative, but since I don’t have any service, and they don’t accept international numbers, I’m not sure how best to proceed. Do you have any suggestions? Thank you so much
Receiving texts requires that you are roaming since you have to be onnected to a network. Unfortunately prepaid simply cannot work for this purpose. Since you got it 2 hours ago, I would try to get it refunded. Prepaid is more difficult to get purchased service refunded, but I really thnk this should count as it’s been 2 hours and purchased not knowing it won’t work for your use.
You’ll need a postpaid plan, or you’ll need to get a VOIP service that gives a Canadian number to receive texts overseas. If you wish to remain with Koodo, you’ll need to get the $15 dollar a month starter plan, which has international roaming, so you can receive MFA texts at no extra cost.
For speaing with a rep while overseas, we can flag a rep here to prpvode assistance. For prepaid, they’re more limited here, and you might end up being better off clicking on the Facebook link at the bottom of this forum page to DM FB for assistance while overseas.
