Alaska Roaming
  • Aug 12, 2022 2:03 AM UTC
  • 473 views
Adam N.
Hi,
I am on Koodo prepaid, and I have US roaming (data, voice, and texts) addons purchased and activated.
I am in Alaska (Anchorage) and my phone is not connecting to any network
(AT&T is available, but says can’t connect)
Phone is a Pixel 3A, with eSim card
Please help!
  • Aug 12, 2022 2:30 AM UTC
Did it work before in the past?
There was some issue with 3G network in US. More here https://www.koodomobile.com/en/help/3gshutdownUS
You could try to reset network settings and see if the pixel can connect to LTE and VoLTE can work in the phone?
Adam N.
  • Aug 12, 2022 4:06 AM UTC
I went into an AT&T store, and they tried one of their sim cards in my phone, and it worked, so it's not the phone itself. (the guy at AT&T didn't provide any help other than that).
I've tried rebooting my phone, disable and re-enabling the e-sim, and reset the apn's to default.
  • Aug 12, 2022 4:11 AM UTC
If so, the issue could be Koodo prepaid. It doesn’t support VoLTE in Canada so I assumed it didn’t support VoLTE in US.
Btw, did it work before in US?
Adam N.
  • Aug 12, 2022 6:54 AM UTC
This site says that roaming includes Alaska…
https://www.koodomobile.com/en/help/long-distance-travel-and-roaming-prepaid
The last time i was in Alaska, I was in Skagway, and I don't think Koodo worked either (it was only a day trip, so I didn't look into it). I have used Koodo in the usa before, but with a different phone a few years ago.
P.S. Thanks for helping, I appreciate it.
Adam N.
  • Aug 26, 2022 9:16 PM UTC
Just to update this, I talked with Koodo today, and it appears that with the AT&T 3G shutdown, there is no more coverage in Alaska (as T-mobile does not have towers there).
  • Guardian
  • Aug 26, 2022 10:28 PM UTC
Correct.  Koodo roams with both AT&T and T-Mobile and both have either finished or in the process of decommissioning their 3G networks.  Koodo prepaid voice calls only work on the 3G network.  Hopefully Koodo gets VoLTE enabled soon.
Mobile data should be available on LTE provided there is actual coverage by one of those two roaming partners.    You mentioned the local AT&T sim worked, so I’m surprised that AT&T didn’t allow you to connect and use mobile data at least.  Did you have roaming enabled for mobile data in your phone?
I would contact Koodo and ask to be credited for the roaming boosters you purchased.
