what does it cost to call puerto rico
  • January 26, 2024
  • 260 views
seangoggin
I have the Unlimited Long Distance Pack and the countries included  are: United States, China, Hong Kong, India, Mexico, Bangladesh, United Kingdom, Argentina, Australia, Brazil, Costa Rica, Colombia, France, Germany, Japan, Korea, Ireland, Italy, Malaysia, Netherlands, Nigeria, Pakistan, Peru, Philippines, Poland, Singapore, Sri Lanka, and Taiwan.
Is Puerto Rico considered  part of the USA?
It is area codes 809 and 787 in the North American Number plan.
The Pay per Use list does not include Puerto Rico as a country
https://www.koodomobile.com/en/payperuse
However if you look at
https://www.koodomobile.com/en/help/long-distance-calling
The rate is listed as 2.75 per minute for Puerto Rico
As opposed to the normal USA rate of 0.80 per minute
  • January 26, 2024
puerto rico isa separate country for long distance calling when you are in canada, but it is part of the US when you are traveling when you use Easy Roam
seangoggin
  • Advisor
  • January 26, 2024
Thank you however I am not asking about Easy Roaming.
I just want to know what it costs to call from Canada.  Which comes down is it part of the US, Alaska and Hawaii are but I guess US Virgin Islands, Guam and PR are likely not.
I guess I have to use Skype to call, since it Is likely not part of US calling so 2.75 a minute.
  • January 27, 2024
That is correct. There are lot of other options available, but Skype is a good alternative to avoid the high long-distance charges.
seangoggin
  • Advisor
  • January 27, 2024
The area code from Puerto Rico is 787 and 939 so from Canada you would call (787) 555 5555
809 is now only the Dominican Republic
  • January 27, 2024
The North America Number Plan includes several nations, so it having 3 digit area codes is not indicative of being part of the US, depsite being an American territory. As you saw, it is 2.75 per minute and with the long distance saver plan, it’s 1.25 a minute.
There is the 28 nation list for the international calling perk, which doesn’t list Puerto Rico, and the legal stuff doesn’t specify American territories are not included, only certain number codes. You’d think that it would be there if anywhere. It manages to specify that Macau is not included as part of China.
I can flag a rep if you like to confirm that American territories aren’t included in that perk.
