Want to upgrade phone and plan but will I be able to keep add on?
  • Oct 18, 2021 7:15 PM UTC
  • 3 replies
  • 261 views
I am a current Koodo customer.  I have a monthly plan with an additional 4GB of data as a $0 add-on.  I want to upgrade my phone.  If I upgrade my phone and keep my current plan, will my 4GB of $0 add-on be kept or will it go away?
Thanks.
Best answer by Bernard Koodo
@kemppaik If you change plans the add-on will fall off.  I see that you ended up upgrading and grabbed another awesome plan.
  • Oct 18, 2021 7:18 PM UTC
Depends what the 4GB add-on was given for initially. Do you remember?
  • Oct 18, 2021 7:28 PM UTC
No, I don’t recall.
Bernard Koodo
  • Oct 18, 2021 8:39 PM UTC
