Voicemail calls keep failing, as do calls to my own number (which should also access voicemail)
  • Oct 28, 2021 10:58 PM UTC
  • 2 replies
  • 925 views
I keep getting “call failed” when I attempt to call voicemail. I can call other numbers, just not voicemail (or my own number).
Sometimes I get “1H1 the client you are trying to reach is not available at this moment, please try again later”, sometimes silence then “Call failed”.  Sometimes I get through, then the call fails.
Best answer by Sophia
Normally to access your voicemail from your own cellphone, you need to long press the number 1.  What happens when you try that?
Sophia
  • Oct 28, 2021 11:59 PM UTC
  • Coach
  • Oct 29, 2021 12:23 AM UTC
Same problem.
Now, however, both ways are working again. Slowly, and a bit erratically, but working.  It seems like there was a problem when the voicemail system.
