Unlimited Long Distance Pack
  • June 26, 2024
  • 1 reply
  • 464 views
I understand this is from Canada to the countries listed on the website, but does this also cover Unlimited Long Distance from Canada to Canada? My current plan is “Unlimited Canada Wide minutes and I am trying to understand if this is the same plus the International or if it is just international and I will end up paying for long distance for Canada to Canada calls.  Thanks
Best answer by Oliver C
anywhere within Canada is free as long as you call from Canada hence the “Canada wide”, this is included in all Koodo plans 🙂 the perk is as you said, only to call other countries while you’re in Canada.
1 reply
  • June 26, 2024
