Signing Up for Two BYOD at Once
  • Oct 2, 2023 6:56 PM UTC
  • 2 replies
  • 182 views
Milton Friesen
I am interested in changing over to Koodo, and would like to move my two exisitng numbers.  However, when I add the BYOD item to my cart, I do not have the option of adding two of them.  Does anyone know how this is possible?
I.e., I’d like to have two lines for $39 each, both with 10GB.
Sophia
  • Oct 2, 2023 8:58 PM UTC
Koodo limits new lines to just one to avoid fraud. You should be able to add a second line shortly after the first one is successfully activated - though I couldn't tell you how soon unfortunately.
  • Oct 3, 2023 12:16 PM UTC
You can add it in-store to get it done right away. However, you will need to wait 45 days before you can add a line on your Self-Serve portal. https://www.koodomobile.com/en/add-a-line
