Roam Issue
  • March 28, 2026
  • 4 replies
  • 30 views
Hi, I have a 14-day Travel Pass for my upcoming 15-day trip to China. I also have the $0 Easy Roam International add-on on my account. Can you confirm that once my 14-day pass expires, my phone will automatically switch to the Easy Roam daily rate for the 15th day if I continue using data?"
  • March 28, 2026
Yep, once your 14-day pass runs out, you’ll automatically switch to Easy Roam’s daily rate; $18 a day for international use; starting on day 15 if you keep using your phone. No need to do anything; it all happens behind the scenes.
Since you’ve already got the $0 Easy Roam International add-on turned on, you’re good to go. Just remember, every day you use data, make calls, or send texts on day 15, you’ll get charged $18. If you don’t touch your phone that day, you won’t be charged at all.
  • March 28, 2026
Hi ​@joeyy
We have looked into it and we can see that $0 Easy Roam International add-on is active on your account and the pay per use rate will apply once the travel pass ends. Just to double check, have you already added the 14-day Travel pass or you plan to add it later? We don’t see it on your account from our end.
  • March 28, 2026
Hi ​@joeyy
I will add it later and thank
  • March 28, 2026
thank you so much
