Returning to Canada from Europe for 2 weeks
  • Aug 21, 2023 8:48 AM UTC
  • 116 views
I am living in Europe for one year but am returning to Canada for a couple weeks. I need to reactivate my paused phone number for this time, or buy a short term solution in order to use my phone when I am back in the country. Can someone please advise the best way to go about this? 🙏 💛
  • Aug 21, 2023 11:58 AM UTC
You can go on a Seasonal Hold plan and reactivate your service once you return back to Canada. https://www.koodomobile.com/en/help/keeping-your-account-open-when-travelling
  • Aug 21, 2023 12:25 PM UTC
Thanks MilyWay. I am not permanently returning to Canada yet, only coming for a 2-week visit. If I sign up for a new plan then I cannot used the Seasonal Hold again. Is there a short-term solution?
  • Aug 21, 2023 2:06 PM UTC
You could get a prepaid Sim card and load a cheap plan, depending on your data needs during this time. I can flag a rep, if you like, to see if they'll make an exception to the once in 12 months since your situation is a little unique.
  • Aug 21, 2023 2:15 PM UTC
Hey Goran,
Thanks for the suggestions! If I could get an exception to the Seasonal Hold limitation, that might be nice. When I spoke to a rep when I was putting my plan on hold he mentioned it would be easy to get a quick situation set up while I visited but I am having trouble finding details. It would be awesome to use an exception :)
Mayumi
  • Aug 21, 2023 3:10 PM UTC
If you don't have any Tab on your account, then I go for the prepaid plan as Goran suggested.
