receiving phone calls in Baja Mexico
  • Dec 1, 2021 6:16 PM UTC
  • 2 replies
  • 202 views
I am in Mexico and I need to receive calls on my Canadian number. What do I need to make this happen?
Best answer by Dinh
If you are a postpaid customer, you have to enable roaming in selfserve. You can follow this https://www.koodomobile.com/easyroam
  • Dec 1, 2021 10:21 PM UTC
Bernard Koodo
@Popeyes Looks like you were able to add international Easy Roam to your line.  It seems you also removed US roaming though. Remember Easy Roam is a free feature to access, you only pay for it when used. So technically you can just leave it on your account at all times.
