Purchased top up data but showing wrong amount
  • Mar 29, 2023 1:51 PM UTC
  • 17 replies
  • 389 views
I purchased 1GB data top up for $25 but only 100MB is showing up.  Please help.
Best answer by Boa_Guy Koodo
@achu  We have sent you a private message for more info.
  • Mar 29, 2023 1:52 PM UTC
Is this in your self-serve usage details that you’re seeing 100mb?
  • Advisor
  • Mar 29, 2023 2:11 PM UTC
Yes, showing 20.1 GB
  • Mar 29, 2023 11:46 PM UTC
Out of curiosity did your usage go over 100mb since and it warned you that you've run out? If not, I could still flag a rep if you like. If yes, I can do so to see what's going on.
  • Advisor
  • Mar 30, 2023 12:39 AM UTC
Usage didn’t go over yet..got a warning that it is 50% done.  Appreciate your help.
  • Mar 30, 2023 1:20 PM UTC
If possible, can you post a snapshot of the text when you bought the $25 1Gb of data? (hide/delete all personal information before posting please)
  • Advisor
  • Mar 30, 2023 1:34 PM UTC
There was no text, no email, nothing, except the data shows 20.1GB...and now it is all used up.
  • Mar 30, 2023 1:52 PM UTC
I am confused, you mentioned you bought 1gb extra? How did you get that one? Was it an add-on in self-serve? Also in the data usage in self-serve, did it show 2 separate data bucket of 20gb and 100mb?
  • Advisor
  • Mar 30, 2023 1:59 PM UTC
My son ran out of data, so I logged in and was offered $25 for 1GB, $17 for 500MB or $13 for 100MB.  I selected the 1GB option.  In Self-Serve, it shows 20.1GB as a single data bucket.
  • Mar 30, 2023 2:10 PM UTC
That was weird, normally you could do it by a text. Can you recheck your number also to make sure you didn't top-up the incorrect number?
Anyway, I will flag a rep here.
  • Advisor
  • Mar 30, 2023 2:27 PM UTC
Thank you - checked again...did not top up an incorrect number...for reference, the number in question ends in 8702
Boa_Guy Koodo
Hi there @achu We have looked into your account, and the number in question is not authorized to do tup ups that is why they received the SMS letting them know that they need to contact and ask the account holder.
It seems that you only unlocked that number to use the PPU 100mb/13$ once.. It's possible that you made a mistake as no top-ups were purchased. If you want to add the 1GB for $25, you can try again, take a screenshot if you are having issues.. Once added let us know and we can see to make adjustments.
  • Advisor
  • Mar 30, 2023 3:34 PM UTC
I added again 1GB for $25.  There is no screen shot available.  Please help make adjustments.
  • Advisor
  • Mar 30, 2023 5:00 PM UTC
Hello - looks like same thing happened again, it is showing that I p
urchased 100MB.  Please HELP!!
Boa_Guy Koodo
  • Koodo Alumni
  • Mar 30, 2023 5:15 PM UTC
  • Mar 30, 2023 5:20 PM UTC
You should disable cellular data on that phone. The messages above saying you made a consent to use the pay per use rate till the end of the billing cycle
  • Advisor
  • Mar 30, 2023 5:34 PM UTC
How do I access the private message?
Boa_Guy Koodo
By clicking on your profile and choosing “Private message” in the dropdown
