possible to block sending of texts outside of canada?
  • Nov 29, 2022 2:34 PM UTC
  • 342 views
Now that many plans don’t have international texting included, is there a way to block or limit the sending of texts that aren’t included in the plan?
Allan M
  • Nov 29, 2022 3:04 PM UTC
There is not unfortunately, only for international calls.
srlawren
  • Hero
  • Nov 29, 2022 4:11 PM UTC
@Allan M do we know what the PPU pricing is for texts that are to international numbers?  Also: what if someone from outside of Canada texts us, is that included (without picking the international SMS/MMS perk), or does that also incur a PPU charge per message?
Allan M
  • Nov 29, 2022 4:46 PM UTC
Canada to international text rate 15¢/outgoing text message and 30¢/outgoing picture and video message
If you’re outside of Canada then you would be charged with the applicable roaming charge. The intl texting perk is only for texts made while you’re in Canada, to an intl number.
srlawren
  • Hero
  • Nov 29, 2022 4:52 PM UTC
Thanks @Allan M.  Yes understood that roaming is different (and I have Easy Roam enabled).  Just changed my plan and it no longer includes international SMS feature (I may yet pick that perk, still deciding) which is why I was asking.  So to confirm, if I’m in Canada, do I get charged to *receive* incoming texts that originated outside of Canada?  From your reply, it looks like only outgoing texts to international numbers (while I’m in Canada) would be charged, and at 15c per msg.
Allan M
  • Nov 29, 2022 4:55 PM UTC
Correct, incoming anything, whether calls or texts are free to receive as long as you are in Canada.
srlawren
  • Hero
  • Nov 29, 2022 5:12 PM UTC
Thanks again, @Allan M.
It’s a little confusing based on how they describe the perk:
 They should really describe it as “Send unlimited international SMS free of charge”, since receiving is always free of charge.
