Plan was downgraded without telling me
  • Oct 30, 2021 7:23 PM UTC
  • 4 replies
  • 180 views
I had a 9 gig plan that was downgraded to 4 gig without notification. This is really bad. I am considering switching providers.
Best answer by Bernard Koodo
@Markus Gallantis Not sure what you mean, your plan hasn’t been changed since you singed up for it over a year ago.
  • Oct 30, 2021 7:38 PM UTC
When you said “downgraded” you meant your plan was changed without your knowing?
Did you upgrade your phone recently? or there was an 5GB add-on in the past with your plan?
  • Oct 31, 2021 12:28 AM UTC
When did you change to the 9gb plan?
When did you notice the plan downgrade?
Mayumi
  • Oct 31, 2021 1:42 AM UTC
Can you check your self serve to see when your plan was changed? And post a screenshot of PDF e-bill wich showing that you had a 9GB plan (without personal info).
Bernard Koodo
  • Nov 1, 2021 2:17 PM UTC
