Plan availability for international students
  • Jan 5, 2022 2:17 AM UTC
  • 538 views
I am an international students, not Canadian citizen, don’t have driving license, and haven’t got a SIN yet.
Can I get a regular plan (not prepaid) and transfer my number at Koodo store? If yes, what document do I need to bring? Study permit? Passport? And what else?
Best answer by Dinh
All you have to do is to pass their credit check https://www.koodomobile.com/en/help/credit-check-requirements
Do you have a Canadian credit card? If you don’t and as you didn’t have a driver license or a SIN card, you might not get a postpaid plan.
  • Jan 5, 2022 2:37 AM UTC
Allan M
  • Jan 5, 2022 3:47 AM UTC
At the corporate Koodo stores you can use a non-expired international passport and study permit.
I would call ahead though to your local store and make sure they're aware of the process before going in. It's not a common process but it's called the "Koodo International Student Program".
  • Jan 6, 2022 2:47 PM UTC
I called local Koodo shop. They told me there isn’t an “international student program”. Probably service in small towns is not so comprehensive like in big cities.
It’s okay. I have applied for SIN. It would only a few weeks to arrive.
  • Jan 6, 2022 4:27 PM UTC
Allan works at a koodo location so I would trust the program exists if he says it does. If you don't want to wait for your SIN, I would get your local koodo shop to ask their manager or call in to Koodo to get more info about the program.
Allan M
  • Jan 6, 2022 5:17 PM UTC
It's a rather hidden away program and like I said would need to be one of the "official" koodo locations so it could be possible it's not something can do or are aware of.
The program does place you on the spending limit program and you can't purchase a phone from Koodo either so it may indeed just be best to wait for your sin number and then go from there😊
