Phone calls while roaming in US
  • Dec 29, 2022 5:46 PM UTC
  • 3 replies
  • 285 views
Hi, I will use easy roam in US while travelling next week. My plan has unlimited Canada wide phone calls. my question:  if I make calls in US -- to Canada, or US local , will I be charged for that? Thanks.
  • Dec 29, 2022 6:01 PM UTC
Yes, you will be charged for any phone calls made to Canada and your destination country on that day. For more information on the Easy Roam feature, you can refer to this page.
  • Dec 29, 2022 6:17 PM UTC
Thanks for the quick answer, and the tutorial. But I am confused, in the tutorial, it says:
If you have Easy Roam:
  • Easy Roam fee will activate from voice usage and will be effective until 11:59 in the time zone you are traveling.
  • Minutes will be used from your monthly plan
My mobile plan has unlimited canada-wide calls, why will I be charged to the calls to Canada?
While I am in US, using Easy Roam, how I will be charged for the calls made from US to US, i.e. how much per minute? I thought it should be free, no?
  • Dec 29, 2022 7:24 PM UTC
Since you have unlimited minutes on your plan, you will not be further charged on a per-minute rate for calls to Canada or the U.S. while travelling. You will only have to pay the Easy Roam fee of $12 per day once it is triggered. https://www.koodomobile.com/en/easyroam
