no roaming in US
  • Feb 15, 2023 6:54 PM UTC
  • 232 views
I have easy roam on my Samsung Galaxy S20 fe 5G, but cannot make phone calls. Have tried everything suggested but no luck. Took the phone into an AT and T store and the tech said everything looked fine, but still no service. Curiously he said Koodo appears to think my phone - self purchased - is 3G. Any suggestions?
BobTheElectrician
Check out this post
  • Feb 15, 2023 8:21 PM UTC
Make sure VoLTE is in your add-ons
  • Feb 15, 2023 11:42 PM UTC
Do you have the Pay-Per-Use International Long Distance add-on included on your account?
If so, have you tried manually selecting your network to see if it works? What about resetting your network settings?
  • Feb 15, 2023 11:50 PM UTC
VoLTE is on.
  • Feb 16, 2023 12:15 AM UTC
VoLTE is on.
On in your self serve add-on area AND on your phone?
Where did you get your phone?
BobTheElectrician
Implementation of VoLTE + wifi calling seems to be different amongst suppliers (US and Canada). Mainly an issue with Android phones. Carrier-supplied phones often have certain features blocked and others added. Just because a phone is “unlocked” does not mean it will work everywhere.
US typical “whitelist”:
https://www.att.com/idpassets/images/support/pdf/Devices-Working-on-ATT-Network.pdf?source=ESSZ0SSPR00T1EsEM&wtExtndSource=20201020164156_AT%26T+Community+Forums__COMMUNITY_3954573197
Even then no guarantees. Had to buy a US phone matched to the local network to get proper service locally, but never got roaming (prepaid) to function.
