Lower Plan Rates Unavailable?
  • March 15, 2026
  • 77 views
In the past, I’ve been able to select from a variety of different plans and pricing regardless of my current phone bill.
        Recently, I’ve been trying to lower/change my phone bill as I now don’t require as much data. It’s impossible, I’ve read all the articles, seen all of the self-serve solutions and still have not figured this out. I just need a cheaper plan, with less data, and the only options I get are more expensive ones or ones that stay the same. If I was able to do this before, what changed?
Best answer by MilkyWay
What is your current plan? Which plan are you looking for?
Have you considered looking at prepaid plans? There is a limited-time offer where you can get 25GB of data for $25 with automatic top-up. https://www.koodomobile.com/en/prepaid-plans
  • March 15, 2026
  • March 15, 2026
Hi, how much are you paying , and do you have a Tab with Koodo as of now?
  • March 15, 2026
I do have a tab, 24 month phone payment. This is my second phone with them. With my past tab, I was able to change my plan, so I’m just a little confused.
  • March 15, 2026
Thank you! I’m not sure if I’d be able to switch from monthly to prepaid while I’m on a 24month phone payment plan aswell.
  • March 15, 2026
If you had a tab as of now, the option is limited though. Porting out to prepaid or another carrier is expensive because of the Tab/Tab bonus repayment.
Since Koodo put a restriction on plan change for your case. Most of the option is available in self-serve. You can try to schedule a call back and ask but I don’t think you can get as a low as a BYOD plan.
