Koodo data speed
  • Sep 30, 2021 12:07 AM UTC
  • 2 replies
  • 455 views
Koodo data speed is so slow. It must be Telus throttled down.
  • Sep 30, 2021 12:52 AM UTC
I was just out using data and didn't have any issue.
Is this a recent issue for you? Unless you have a 3G starter plan you should be able to get up to LTE speeds depending on your connections.
Try restarting your phone.
  • Sep 30, 2021 2:42 PM UTC
I get good speed with Koodo, maybe it was a specific issue.
