I am in USA and need my phone to work here
  • Mar 30, 2022 7:37 PM UTC
  • 3 replies
  • 205 views
Joanne-Doug Roche
How do I get my phone plan updated to call US numbers while here??
Best answer by Dennis
Enable Easy roam. You can do this in self serve. You may need to restart your phone afterwards.
https://www.koodomobile.com/help/easy-roam
  • Mar 30, 2022 7:39 PM UTC
  • Mar 30, 2022 8:45 PM UTC
If it still doesn't work, make sure to check your add-ons for international voice roaming. It should be automatic with easy roam enabled. Here's the link for more info on easy roam so yoh know the cost to expect to pay:
https://www.koodomobile.com/easyroam
Timo Tuokkola
If you are a prepaid customer, you will need to add a US roaming booster to your account.
