How to tell if I am paying for 4G/LTE or 5G?
  • Aug 30, 2023 5:16 PM UTC
  • 2 replies
  • 489 views
I have seen advice to check your plan details to see if you have 4G/LTE or 5G support. My plan (pictured below) is quite old and does not state this information. How do I know what I am paying for?
Sophia
  • Aug 30, 2023 9:55 PM UTC
All older plans would be 4G/LTE. You can only get 5G on a (newer) plan that specifically mentions that. That said, there are much better plans around nowadays than yours, so I would highly recommend you wait until Black Friday and upgrade yourself to a killer plan :)
  • Aug 30, 2023 9:57 PM UTC
Thank you for the clear answer.
