How to downgrade my koodoo plan?
  • Jan 13, 2023 6:07 PM UTC
  • 4 replies
  • 1601 views
Hi Koodoo Community!
I have $55 plan for 6GB. I want to downgrade my plan and get a cheaper plan because I don’t need extra data anymore. When I try to change my plan in the website, the options only include plan that has higher cost (55, 60, 65 postpaid plan).
  • Jan 13, 2023 6:08 PM UTC
What plan are you wanting to get and do you have a tab currently?
  • Jan 13, 2023 7:47 PM UTC
Hi Dennis!
What are the possible lower plans that I can avail? I don’t have a tab.
Mayumi
  • Jan 13, 2023 7:59 PM UTC
Hi Dennis!
If you don’t have any tab on your account, then you can switch to one of BYOD or Starter plan.
But, you need to set up a call back to talk to a rep to do it. Make sure you tell them that no charge for plan change since you can’t do this through self serve.
  • Jan 13, 2023 8:08 PM UTC
https://www.koodomobile.com/en/rate-plans
Here are the Koodo plans you can choose from
