How to Check Network Compatibility Using IMEI?
  • Aug 23, 2021 10:48 PM UTC
  • 4 replies
  • 2400 views
Mostafa Shalaby
Hey, I am currently using the Pocophone F1 as my device and I want to know if it would be compatible with koodo, using its IMEI. I tried willmyphonework.net , however it doesn't have my device listed.
Thanks in advance!
Best answer by Dinh
If your phone only had 1 compatible band, it might not work well in all area. I recommend you not to buy it. Otherwise, it would be a headache to find which location is good and which isn’t.
  • Aug 23, 2021 10:54 PM UTC
You can find Koodo network information here https://www.koodomobile.com/en/help/my-phone-compatible-koodo From that you could check the specifications of the phone and find out if the phone is compatible or not. The IMEI tool isn’t always correct btw.
Mostafa Shalaby
Great, I just did some research and found my device is compatible with 850 MHZ. Is that enough, or does it have to be compatible with more than one frequency?
  • Aug 23, 2021 11:09 PM UTC
Mostafa Shalaby
Thank you so much!
