How much do I pay for choosing another perk as an add-on?
  • Dec 9, 2023 10:48 PM UTC
  • 1 reply
  • 139 views
My plan allows 1 perk, I have chosen Unlimited International Calling, and I would like to keep that and add Unlimited International SMS.
How much do I pay monthly for choosing the second perk as an add-on?
1 reply
Sophia
  • Dec 9, 2023 10:53 PM UTC
It depends on the perk. If you add the one you want, it should tell you how much it would cost. Some are $3 all the way up to $10, so I would suggest you add the most expensive perk as your free one, and the cheaper one as the extra perk. You have already picked International calling as your perk, so all the other should be cheaper :)
