error changing rate plan
  • November 26, 2025
  • 3 replies
  • 37 views
Trying to change my plan to the $50 80gb of data plan n it keeps giving me an error saying I can’t choose perk rn. Tried doing it without picking one n it says the same thing. Id like it to be paired with the rollover data perk please
  • November 26, 2025
You’re definitely not the only one hitting that perk selection error when trying to change plans; lots of folks are stuck at the same spot, even when they skip picking a perk or try a different one. Super frustrating!
Quick things to try:
- Log out, clear your browser cookies, then log back in and try again.
- Switch browsers, or use incognito/private mode (sometimes a different device helps too).
If you already tried all that and it’s still broken, hang tight—Koodo’s self-serve sometimes just glitches for certain plans/perks, especially with perks like rollover data.
Just to double-check: Are you sure the $50/80GB plan includes the rollover data perk? Sometimes not all plans support every perk.
Let me know if you’ve tried all the above and it’s still not working. If so, I can help point you to the next step!
  • November 26, 2025
This seems to be an ongoing technical issue. Let me flag a rep for you.
  • November 26, 2025
Hi ​@TBrett95
We have just sent you a PM to confirm some more details and further assist, please check your community inbox when you get the chance.
