Does US unlmited add on include calls to/from Canada when in US?
  • Nov 17, 2021 3:15 PM UTC
  • 1 reply
  • 585 views
Does unlimited US add on include calls to /from Canada when in the US?
Best answer by Goran
It's only for calling American numbers while in Canada as per the add-on description:
“  Get unlimited long distance minutes for your calls from within Canada to the U.S.  Restrictions: Calls made to phone numbers starting with the following six digit combinations are not included in this add-on: 559-726, 712-775, 712-432, 605-562, 605-475, and 530-881. Calls made to these numbers will be billed at your standard pay-per-use rate.  “
If you are in the US, you are roaming and will need easy roam if you wish to make unlimited calls while in the US for a flat fee. Otherwise it's a really high pay per use rate.
1 reply
  • Nov 17, 2021 7:03 PM UTC
