Does Unlimited Long Distance Pack cover my calls while outside Canada?
  • April 18, 2024
  • 2 replies
  • 484 views
If I pick the Unlimited long distance perk does it cover my calls while I am in one of the long distance countries ?
For example I know I get free long distance to a US number if I am calling from Canada.
Does it cover the same call to the US number if I am roaming in the US ?
Get unlimited long distance calling to 28 countries including the US, China, Hong Kong, India, Mexico, Bangladesh, and the UK from anywhere in Canada.
Best answer by Allan M
No, it’s only good for while you’re in Canada, calling to one of those numbers.
Allan M
  • April 18, 2024
Timo Tuokkola
  • April 18, 2024
The fee for roaming, (whether using easy roam or pay per use roaming), does cover calls within that country though, so there would be no additional long distance charges for calling a US number while in the US, only the standard roaming rate.
