Device care
  • Sep 24, 2023 7:58 PM UTC
  • 1 reply
  • 228 views
If you purchase a phone through Koodo and pay the full amount upfront and then add device care and a plan but then decide to cancel the plan a few months later, can you still keep paying for the monthly device care or are the plan and device care linked together?
Thanks
Best answer by Allan M
The services are paired with your Koodo line. If you cancel your line with Koodo or switch carriers, then you would no longer have the device care.
1 reply
Allan M
  • Sep 24, 2023 8:31 PM UTC
