Husband traveled to US easy roam added and data working but calling is not. Any suggestions??
What phone does he have? I believe Volte is needed for calling in the US..
Yes we've made sure that is active on the phone
Which phone are you using? and which roaming carrier are you on? VoLTE is picky sometimes. Have you tried to reset network settings to see if that can activate your VoLTE?
