changing plan & promotion
  • Nov 21, 2022 1:50 AM UTC
  • 7 replies
  • 139 views
When changing a plan, am I gonna loose my current promotion?
  • Nov 21, 2022 2:20 AM UTC
It depends though. Which promotion was it?
  • Nov 21, 2022 2:30 AM UTC
It’s an extra data on the top of my data included in a plan for 6 months
  • Nov 21, 2022 2:51 AM UTC
If the add-on was a promotion of your plan at that time, you would lose it when you switch your plan to a new one.
  • Nov 21, 2022 3:03 AM UTC
Are you planning to switch to a plan with similar or more data? Then it's kind of moot.
  • Nov 21, 2022 3:16 AM UTC
No, I’m planning to switch to a plan with less data..
  • Nov 21, 2022 3:17 AM UTC
Yeah, that’s the thing, I don’t remember if the promo was for a new customer or for the particular plan..
  • Nov 21, 2022 3:55 AM UTC
 it is the same thing though, data add-on was attached to the plan (that was for new customers).
