Changing data plan?
  • Dec 17, 2022 1:29 AM UTC
  • 2 replies
  • 378 views
I'm thinking of changing my data plan, when's the best time to do this? Last time I change half way through my plan and I got charged for it.
Best answer by Sophia
You can change at any time, but to avoid proration, it's best to change close to your plan renewal date.
You don't get charged extra either way, so if you see a special offer that you like, you're best off to change before the offer expires.
Sophia
  • Dec 17, 2022 2:10 AM UTC
  • Advisor
  • Dec 17, 2022 8:43 AM UTC
One thing I would add to what Sophia said is that you're allowed one change per billing cycle. So if you are anticipating special deals to be available later that same billing cycle (eg. Black Friday or Boxing Day) it may be smart to wait for those. That can be a bit of a gamble though, so take it for what it's worth.
