Bermuda long distance from Canada
  • Feb 15, 2023 6:32 PM UTC
  • 96 views
Does anyone know if the unlimited long distance calling to the US include Bermuda? Thank you
  • Feb 15, 2023 6:41 PM UTC
Bermuda is a British Overseas Territory, and not normally included in long distance US calling, roaming, etc. It is part of the NANP, but still not the US.
  • Feb 15, 2023 7:00 PM UTC
Thanks Goran, my unlimited also includes UK long distance. Any chance you know if that will fall under the UK calling instead? Thank you
  • Feb 15, 2023 8:18 PM UTC
No. Koopd treats Bermuda as its own separate country
  • Feb 15, 2023 8:33 PM UTC
Thanks Dennis. So I'm assuming it doesn't fall under UK calling either.  Thank you 😊
  • Feb 15, 2023 8:35 PM UTC
Correct.
