Will any new phone work with Koodo
  • Sep 11, 2021 11:06 PM UTC
  • 4 replies
  • 771 views
Hello.  I notice Koodo doesn’t have any Google Pixel phones available in their shop, and I was wondering if I buy a Pixel 6 this fall directly from Google, could I easily transfer the sim card from old to new phone and go about my merry way, or do I have to make sure the Pixel 6 works with this network?  I vaguely remember something about certain phones not working with certain carriers.
Thanks for any info.
Best answer by Timo Tuokkola
As long as the phone supports the following frequencies it should work just fine:
Frequency bands & compatibility
Koodo uses the following frequency bands to provide our service:
4G LTE and LTE Advanced:
2100 MHz downlink and 1700 MHz uplink (AWS)
1900 MHz
700 MHz
850 MHz
HSPA:
850 MHz and 1900 MHz (UMTS)
Timo Tuokkola
  • Sep 11, 2021 11:18 PM UTC
1900 MHz
700 MHz
850 MHz
HSPA:
  • Sep 11, 2021 11:20 PM UTC
If you buy it directly from Google Canada, it should work fine and fully compatible with Koodo.
  • Sep 12, 2021 2:56 AM UTC
You are right that certain phones do not work with particular carriers, since they may not support the correct bands and frequencies or they may have regional restrictions that are not used in North America. However, it is unlikely the Google Pixel falls under this category.
  • Sep 13, 2021 6:16 PM UTC
Thank you very much for your responses.  :slight_smile:
