travel pass US not working
  • February 3, 2026
  • 4 replies
  • 33 views
I’m currently in the US and the USPASS7 option is not working. Says invalid keyword. How can I get this added ?
  • February 3, 2026
This has been a common issue over the last few days. You can either have a rep through Koodo’s expert messaging via Koodo assist add the pass for you or I can flag a rep on this platform to see if they can add the pass.
I would try the Koodo expert messaging first as response times on this platform can vary. So, if you need the pass ASAP, I would try there in case you get a faster response. Note they’re open 9am to 9pm local time Mon-Fri.
Support Homepage | Koodo Mobile
  • February 3, 2026
Thanks  I will try but if you can flag a rep for me as well I would appreciate it.
  • February 3, 2026
Sure thing 😎
Make sure you’re logged into the community using your Koodo self serve credentials and the rep will be able to take a look. When they respond, it will be here as I have. 👍
  • February 3, 2026
@RLMac
We see that you managed to get help from the Expert Messaging team in the meantime. Please let us know if you need help with anything else.
