Switched over to 4G plan but phone still operating on 3G. How to fox?
  • Jan 25, 2023 12:23 AM UTC
  • 3 replies
  • 759 views
*Spelling error FIX****
Like the title says i’ve switched to a 4G plan a few months back but it is still showing on my phone that i’m on 3G for my data. I have an Iphone XR.Fully updated.
  • Jan 25, 2023 12:42 AM UTC
Have you restarted your phone after switching your plan?
  • Jan 25, 2023 12:43 AM UTC
How do you know you are operating on 3G only?
Does the network only say 3G?
Even if you are on a 3G plan, it should still connect to the 4G and LTE network. Koodo just throttles your speed
  • Jan 25, 2023 7:28 AM UTC
Make sure your iPhone XR is not set to 3G. To check, go to Settings > Cellular (Cellular Data On) > Cellular Data Options - tap Voice & Data and select 4G (if available) or LTE.
