Stream Bundle Activate stuck
  • Jan 4, 2025 4:05 PM UTC
  • 11 replies
  • 275 views
Hello, I recently got the stream plus plan. I got all of them activated but telus tv. It set me up but on the koodo website it still shows activate, alongside I am getting emails asking to set it up from Koodo. How can I fix this, any assistance is apprecciatted thanks.
Best answer by Flo Koodo
Thanks it takes me to the webside I am on desktop. Should I use my phone?
It might be that the reason why it doesn’t see it as activated. If you can please try on Android/ iOS and see what happens after installing the TELUS TV+ app. If that doesn’t fix the issue, please let us know.
  • Jan 4, 2025 4:47 PM UTC
Hi ​@Jamvencarter
For TELUS Films and Series, you don’t need to activate it, simply log in through your Koodo account here https://streamplus.telus.com/telus-login?returnUrl=%2F
More about TELUS Films and Series can be found here https://www.koodomobile.com/en/help/stream-plus
  • Jan 4, 2025 6:30 PM UTC
I am still getting emails though in rergrads to activating it even though i can sign in jsut fine. How can I get the specific activation email to stop?
  • Jan 4, 2025 6:53 PM UTC
​@Jamvencarter
Are you also able to log in here, using your Koodo self serve credentials: https://telustvplus.com/?
  • Jan 4, 2025 7:01 PM UTC
Yes I can, the issue is gettign repeat emails to activate it even though I did so over a week ago.
  • Jan 4, 2025 7:22 PM UTC
Got it!
We checked on our end and indeed it appears that it’s not activated.
Just to double check, when you click the Activate button in self serve, are you prompted to download the TELUS TV+ app?
  • Jan 4, 2025 7:27 PM UTC
Allan M
  • Jan 4, 2025 7:38 PM UTC
Is the issue that you’re unable to login and use it or unable to get it to not say activate anymore?
  • Jan 4, 2025 7:45 PM UTC
Unable to get it to not say activate anymore. As I am gettign emails to activate it but as far as I can tell it works as I log in through koodo. But the button stays saying activate with a email every week to activate it.
  • Jan 4, 2025 7:47 PM UTC
  • Jan 4, 2025 9:23 PM UTC
It is now fixed thanks!
