SMS/MMS Voicemail from Unknown numbers
  • Aug 9, 2023 5:47 PM UTC
  • 2 replies
  • 78 views
I have gotten 3 sms/mms file voicemail from unknown numbers from Ontario.
Is this a scam or a virus/malware?
  • Aug 9, 2023 6:00 PM UTC
Iunno about a virus. Probably a scam. If you don't recognize the number you could just ignore them.
I assume you set up premium voicemail to forward voicemails to mms?
  • Aug 9, 2023 6:11 PM UTC
Do you usually receive VM files as MMS? If not, definitely ignore them.
