Roaming didn't work in Cuba but worked in the US a wek prior
  • Dec 2, 2021 3:17 AM UTC
  • 374 views
Hello!
I have an odd issue when roaming worked fine in the US and a week later in Cuba it didn’t work at all.  I wasn’t able to connect to Cuba’s mobile operator neither automatically nor manually.  The error during manual connection was “Your SIM card does not allow a connection to this network”.  How could it work in one country and not in another?  The phone was restarted - to no avail.
Thanks!
Best answer by Allan M
Hi @Goran!
It is a postpaid plan indeed
Do you have the International easy roam add-on on your plan along with the international voice & data roaming add-ons?
  • Dec 2, 2021 3:37 AM UTC
Do you have a postpaid plan?
  • Organizer
  • Dec 2, 2021 4:56 AM UTC
Hi @Goran!
Allan M
  • Dec 2, 2021 5:13 AM UTC
Hi @Goran!
  • Organizer
  • Dec 2, 2021 2:36 PM UTC
Hi @Allan M ,
You are right -- I only have Easy Roam, not the International Voice and Data add-on.  That’s where the problem is.  Thank you for pointing me in the right direction!
The only puzzle is why the roaming worked in the US…..  I guess the US is not a “foreign country”? :-)
Thank you!
Allan M
  • Dec 2, 2021 4:07 PM UTC
Hi @Allan M ,
Thank you!
Yea the international voice and data add-ons are for using your phone outside of North America. For using it I'm the states, you don't need anything special!
We're you able to find them and add them in your self serve account?
  • Organizer
  • Dec 3, 2021 7:31 AM UTC
Hi @Allan M ,
Thank you!
Hi Allan,
Yes I was.  Thank you!
