Porting out number on seasonal hold
  • Nov 27, 2022 2:47 PM UTC
  • 1 reply
  • 236 views
Hi,
I want to port out my number but it is on seasonal hold plan so I can’t receive text. I would like to avoid any extra cost from changing my plan. Is it possible for me to authorize the transfer via email? Or do I have to directly call the rep for approving? Thanks!
Best answer by Allan M
You can change your plan via self serve to the cheapest one you can select, then immediately port out to the other carrier.
You would only incur 1 days worth of that plan in charges and this is the same thing that a rep would have to do over the phone for you.
1 reply
Allan M
  • Nov 27, 2022 2:56 PM UTC
