Port number from NumberBarn
  • Oct 12, 2022 10:30 PM UTC
  • 3 replies
  • 517 views
I am trying to change my phone number and don't like the options Self Serve provides. Talked to customer service and they said there's nothing they can do.
I found a service online called NumberBarn that will sell me a number that I want. They say on their site to check with your carrier if they will accept a port.
Two questions:
1) Does Koodo accept incoming number ports from NumberBarn?
2) Can I port in a number to replace my existing number (and keep my current plan)?
Best answer by Allan M
You can use this tool to check if the number is eligible to be transferred:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
Big thing is to just make sure it’s a Canadian number.
  • Oct 12, 2022 11:28 PM UTC
Two questions:
Yes, that is correct. You can port in a number to your line and it will replace your current one with Koodo, as long as it is not currently with Telus, Koodo, or Public Mobile. The plan will stay the same.
Allan M
  • Oct 13, 2022 12:31 AM UTC
  • Oct 13, 2022 5:52 PM UTC
Thanks for the quick replies. The eligibility tool says the number I'm looking at is good, so I should be good to go.
