Port landline number to Koodo phone?
  • Apr 13, 2023 8:26 PM UTC
  • 439 views
I have been using Koodo for my cell service for a few years now. I’m currently downsizing a bit and I want to cancel my landline and start using the landline phone number on my Koodo phone. How would I go about doing that?
Sophia
  • Apr 13, 2023 8:36 PM UTC
It’s very simple, we have done the same and never looked back. Sign up with Koodo and get assigned a temporary number. Once everything works to satisfaction, start the process of porting in your landline. DO NOT CANCEL YOUR LANDLINE! It will be cancelled by porting your number to Koodo.
It will take 3 business days (no shortcuts there) and then you can use your old landline number as a cell number from then on.
Edit: oh, I noticed that you said you have a Koodo cellphones number. You’ll lose that if you port your landline number on top of that (you can only have one number per line)
  • Apr 13, 2023 8:40 PM UTC
Thank you Sophia. I’m already signed up with Koodo. I don’t mind losing the number I currently have on the cellphone. How do I start the process of porting in the landline?
Sophia
  • Apr 13, 2023 8:44 PM UTC
That’s even easier ^_^
You’ll need to visit self serve and go to Mobile Services. Then Manage Your Number - then follow the instructions under “Transfer Your Number from Another Provider”. The hardest part is waiting for the port to finish 😂
  • Apr 13, 2023 10:36 PM UTC
You should still be able to make calls, but receiving them during the porting process won’t happen. Just something to plan for.
  • Apr 13, 2023 11:09 PM UTC
To add on to Sophia’s comment, it is important to restart your phone after the port transfer. Otherwise, it may not work properly.
  • Apr 14, 2023 4:38 PM UTC
On koodo’s help page here
https://www.koodomobile.com/en/help/moving-your-number-koodo
For FAQ #5, they do suggest you request a call back.
I think you are fine following Sophia’s direction, but I do know porting a land line over does take longer than a cellphone number and may run into additional difficulties.  If your port does run into any issues, just know a callback via koodo assit may be  required.
