next radio
  • Dec 18, 2021 1:02 PM UTC
  • 13 replies
  • 396 views
Anybody find a way to get the radio to work with out  using data
Timo Tuokkola
If the fm radio chip isn't enabled on the phone in question, it can't be done.
  • Organizer
  • Dec 18, 2021 3:55 PM UTC
it worked fine till it upgraded to android 11,then it stopped working
  • Dec 18, 2021 6:43 PM UTC
What phone do you have?
  • Organizer
  • Dec 18, 2021 7:03 PM UTC
Samsung s10
  • Dec 18, 2021 7:33 PM UTC
I’m not sure if this will work, but one comment in the review section of the Next Radio app on Google Play mentions not to enable location and instead of selecting a country select ‘other’ and this should get you to the FM radio section.
NextRadio Free Live FM Radio
  • Organizer
  • Dec 19, 2021 4:09 PM UTC
i tryed that ,still not working, i think you have to hack the phone, to give the proper permisions
  • Dec 19, 2021 4:46 PM UTC
Are other people reporting the same issue with the same phone?
  • Organizer
  • Dec 19, 2021 5:15 PM UTC
Seems  like any phone  running Android 11 ,they stopped the next radio app  from getting access to the fm chip
  • Dec 19, 2021 5:17 PM UTC
It does not seem like the developer made any changes with the update. I’m afraid you are out of luck on that. https://forums.androidcentral.com/samsung-galaxy-s10e/1021482-if-you-use-nextradio-dont-update-android-11-a.html
  • Dec 19, 2021 8:09 PM UTC
Seems there are some other reasons why NextRadio is no longer.
https://radioink.com/2018/10/11/emmis-pulling-the-plug-on-nextradio/
  • Organizer
  • Dec 20, 2021 3:40 PM UTC
looks like no more offline radio on newer phones ,unless some one can figer out how to access the fm chip
  • Dec 20, 2021 5:38 PM UTC
A different scenario with Mr. Reid. Sadly, Spirit1 & 2 (FM radio) went the same route.
https://forum.xda-developers.com/t/spirit1-spirit2-real-fm-radio-general-thread.1059296/
  • Dec 20, 2021 5:50 PM UTC
Pretty sure jailbreaking might have something to reactivate it but most likely will void the warranty
