Network connection dropped. No phone or mobile data
  • May 18, 2023 2:14 PM UTC
  • 287 views
I am unable to make phone calls or use mobile data. My bills are paid up. I’ve restarted my phone several times.
Sophia
  • May 18, 2023 4:00 PM UTC
Are you getting some error message on your phone? What phone is it? Can you connect to Koodo’s network?
  • May 18, 2023 4:08 PM UTC
Just that there is no network connection.
I followed all the prompts on the digital assistant.
I can’t connect to mobile data and can’t send/receive phone calls text messages. Nothing appears in the outages map. I can’t use call back service as I have no alternate phone.
Sophia
  • May 18, 2023 4:44 PM UTC
Could be a faulty SIM or connector - is it possible for you to try the SIM in another phone? Does it show any networks in the list?
  • May 18, 2023 4:48 PM UTC
I doubt that is the problem, as my son has the same issue with his phone. We are on the same plan with Koodo.
  • May 19, 2023 5:12 PM UTC
Could there be a network outage in your area?  Koodo uses the Telus network.
https://www.telus.com/outages
