Need Assistance with Voicemail Reset
  • Oct 13, 2022 11:30 PM UTC
  • 7 replies
  • 313 views
Hello, My voicemail had been down for a few days. I receive a “call failed” message. It appears a reset from a rep will fix the issue. I have a callback scheduled for 2 days from now but if this would allow this to be fixed faster I would appreciate it. I have work messaged piling up and its slightly inconvenient! Thank you in advance for your help.
Best answer by Boa_Guy Koodo
Here is an article that could help:
Sophia
  • Oct 14, 2022 12:51 AM UTC
I can flag a rep if you wish. Do you use the same email here as for your account?
  • Oct 14, 2022 4:01 AM UTC
I did yes! Thank you for flagging this
Sophia
  • Oct 14, 2022 4:08 AM UTC
Done 😊
Boa_Guy Koodo
Hi there, @aejackes ! We have reset your voicemail as requested.
  • Oct 14, 2022 1:54 PM UTC
@Boa_Guy Koodo thank you for the assistance but it appears to still not be working. Are there any other steps to take or should I wait for my call back?
Boa_Guy Koodo
  • Koodo Alumni
  • Oct 14, 2022 1:57 PM UTC
  • Oct 14, 2022 2:17 PM UTC
Thank you! This solved it. Very grateful
