lost mms capabilities
  • Feb 12, 2023 11:28 PM UTC
  • 358 views
I have a phone that is not on the list of affected phones that was presented on the Koodo website (Galaxy S9 - SM-G960U1). I followed the reset directions from a previous post and mobile data is activated. Why am I now longer able to send gifs, pics or video? I have never had a sim card.
Best answer by truet123
I checked everything. All was good except the APN type was listed as "Default, supl, MMS, dul". I eliminated "dul" and I changed my default messaging app to Google messages. I can send MMS now. Problem solved.
Thanks for your help. Appreciated!
  • Feb 13, 2023 12:31 AM UTC
Eh, as you mentioned you “never had a sim card”Could you explain more detail about this?
I asked because  Koodo service need an active sim to work. As of now, are you a current Koodo customer?
  • Rockstar
  • Feb 13, 2023 12:45 AM UTC
Sorry. My mistake. I meant to say SD card. Not that should have anything to do with the MMS issue.
Mayumi
  • Feb 13, 2023 12:52 AM UTC
Is it only MMs capability lost ?
Can you send/receive text? And your data working?
  • Rockstar
  • Feb 13, 2023 12:53 AM UTC
Only MMS capability. Everything else is fine.
  • Feb 13, 2023 1:20 AM UTC
Could you check your APN settings to see if it was set correctly as per this https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Also, was RCS was on in your device?  https://www.koodomobile.com/en/help/next-generation-messaging
  • Rockstar
  • Feb 13, 2023 2:03 AM UTC
