Issue with calling
I am unable to make or receive calls from my Koodo number. My internet is working fine, and I have a signal, but when I try to call someone, there is no response, and the same issue occurs when others try to call me.
Did this help you find an answer to your question?
  • Organizer
  • March 24, 2025
So the reason I found is Koodo recently upgraded its network to VoLTE, but my phone does support VoLTE — I use my other SIM card on VoLTE without any issues. However, I don't see an option to enable VoLTE for my Koodo SIM. What could be the reason?
  • 29056 replies
  • March 25, 2025
What is the other sim that works?  Is it Koodo?
What phone are you using?
  • Organizer
  • March 25, 2025
No, the other SIM is from another country, running on international roaming and using Bell’s network.
My phone is not supported by Koodo for VoLTE calling, and I don’t think they will add it, even though they technically could without any issues.
I think I need to switch from Koodo to another provider, like Bell.
  • 13564 replies
  • March 25, 2025
If you wish to keep your phone, you’ll have to find a carrier that doesn’t have a whitelist for VOLTE support. Which phone model do you have, out of curiosity?
  • 29056 replies
  • March 25, 2025
Did voice work previously?  Or this was your first attempt at using Koodo?
Koodo also has numerous devices that are available with VoLTE that will work.  I recommend checking them out.
  • Organizer
  • March 25, 2025
It used to work with Koodo before they upgraded their network from 3G to VoLTE.
  • Organizer
  • March 25, 2025
Bell supports my device for lte . I guess I have to use that
  • 29056 replies
  • March 25, 2025
What town or city are you in?
Koodo is not completely phasing out 3G just yet, only 1 of the bands are being repurposed to 4G
  • Organizer
  • March 28, 2025
I am in Mississauga
  • 13564 replies
  • March 28, 2025
I have read that Telus has removed its whitelist a few months ago, but it’s not entirely 100% across any device. I haven’t found any updates for Koodo, other than that Koodo is currently using Telus’s IMEI checker to confirm if VoLTE will work. The Koodo site still maintains a list of compatible phones for VoLTE, including IMEI ranges.
I know it used to have a hyperlink to Telus’s checker, but it doesn’t seem to have it anymore, or I missed where it is. You could try it, and if it greenlights your model, you could try scheduling a callback to speak with tech support about it, and if they can’t or won’t do something on it, then you may well have to pick a carrier that will support the phone that you use.
  • Organizer
  • March 28, 2025
I have already checked, and it specifically says that my phone is not compatible:
‘Your phone is not compatible. This phone will not work on the TELUS VoLTE network.’
