In the UK and my phone is not allowing me to make calls to Canada
  • Jul 25, 2022 9:16 AM UTC
  • 4 replies
  • 174 views
EasyRoam and International Data Romaing are added. Can you help? Thank you!
Best answer by Boa_Guy Koodo
Hi there, @reasonableinstrument!  Here is a helpful article for troubleshooting.
  • Member
  • Jul 25, 2022 11:18 AM UTC
Hi can you give me more details?
  • Jul 25, 2022 11:24 AM UTC
Check for International voice roaming in add-ons as well. Are you connected to a network?
Bernard Koodo
@reasonableinstrument Everything setup correctly on your account.  Pls power cycle your phone (keep it off for at least 60 seconds) to see if it help reconnect to UK networks.  Once the phone is turned back on, if it still doesn’t connect to any network pls go into your settings under ‘cellular’ and manually locate/force a network connection.
Boa_Guy Koodo
  • Koodo Alumni
  • Jul 25, 2022 11:48 AM UTC
