I was charged for easy roam when i applied for a travel pass.
  • December 2, 2025
  • 11 replies
  • 65 views
I recently traveled to Barbados and texted  “CAR7PASS” to 7626 and received a message back stating that i’d successfully added Caribbean and Mexico easy roam travel pass. I checked my bill when I got home and I was still charged the $18 a day for easy roam without the travel pass. Did I do something wrong?
Can this be rectified?
  • December 2, 2025
Did you use your phone right after texting the code? The pass only activates when you first use data, call, or text in the country.
If you used your phone before the pass activated, you might get charged for those days.
Check your Koodo account online; see if the travel pass shows as active during your trip.
If it does and you’re still charged, post a screenshot of your usage and charges here. Might need to flag a rep.
  • December 2, 2025
When you sent the text to add the travel pass, you were roaming at normal easyroam rate. Hence the fee applied.
It is advised that you add the travel pass before you leave Canada or ask a rep to do it while overseas.
  • December 2, 2025
I should have mentioned I applied the travel pass days before I left Canada!
  • December 2, 2025
Hey there,
Weird that you got charged daily Easy Roam instead of the travel pass. Usually, texting the code should switch you to the pass rate.
I’ll check that, thank you! I should have mentioned that I activated travel pass on the 14th of November and left Canada on the 16th.
  • December 2, 2025
If that was the situation I saw a similar case in the forum. Can you double check the number of roaming days? You might have exceeded 7
  • December 2, 2025
Thank you! I just checked my bill and it says the total number of days used was 7!
  • December 2, 2025
  • December 2, 2025
Editted:So I double check the Koodo roaming link https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes?
I couldn't find Barbados listed there! It might be the reason why you were charged for normal roaming fee
  • December 2, 2025
  • December 2, 2025
Their Caribbean destinations didn't include Barbados, it seems
  • December 2, 2025
oh, that’s too bad!! Thanks for your help!
